Sizing Module not uploaded to LMS
In your case the root directory is the main html folder that also contains index.html. Copy and paste the above code into Notepad, do a Save As, choose Type All Files, save with the name "launcher.html" into the html folder and then open this file. You'll see that it's a simple webpage with a "click here to launch the WBT" and it will open it in a separate window with no toolbars.Edited By: rhall01 on 2008-4-15 15:12:0
