Sizing Module not uploaded to LMS
You might be able to search the web for some HTML or CSS that you could add. I would find some code and then change the CSS tag name to body and see if I could get it to work.You might be able to search the web for some HTML or CSS that you could add. I would find some code and then change the CSS tag name to body and see if I could get it to work.
