Shockwave File problem
- How can I resize the screen size of the SWF
You can resize the size of the swf by changing the properties, or you can resize it by moving the corners around when you select it.
- How can I SWF file on screen so that it gives me more space on the left hand side to place text etc during Run mode
What I do is hide it in the left hand menu. You can hide items by turning on the view icon in: File->Preferences->General Tab->Show visibility check boxes in the left-hand pane
