Scrolling text box issues
It sounds like the text is wrapping around the button object, but it's not supposed to do that if you have text scrolling enabled.Do you have to use a button? Instead of buttons to close my text boxes, I just add a line to the top of the box, right justify the word "Close" which I underline and make blue like a hyperlink. I then add the on click; close action to the entire text box. It works great. Putting buttons in text boxes is pretty tricky. I use it for my Exit confirmation window but it's not recommended.Russ
