Screen Size and Layout Problems
@amacadam]Is there a way to make Lectora regulate the size of the window that is launched in (since the LMS is launching the course using a link, I assumed that it would launch at the designated size that I set in Lectora?)As Ben mentioned, the LMS is opening the window, so it should set the size. However, this is code you can use to force set the size of the window (set the width/height parameters appropriately to your course page size):This is added as an External Html Object, object type, Other and place on the first page in the title. [/CODE wrote:
