Screen Size and Layout Problems
Hi, Thanks for the help (and reassuring me that I'm not going crazy!)The window size is huge when I preview it in the Browswer, but I thought that there should be a way to regulate this using Lectora? Is there a way to make Lectora regulate the size of the window that is launched in (since the LMS is launching the course using a link, I assumed that it would launch at the designated size that I set in Lectora?)Thanks for the formatting info - this text is coming from the PPT integrator and I'm assuming that's the problem with the formatting issue.Thanks again for your help!
