Screen Size and Layout Problems
First, browsers do not always render things exactly as they are in Lectora page. Many browsers, many slight differences. To test to see if it is the LMS or the Browser, go to an offending page in Lectora. Click the Preview in Browser button (not just Preview). If the page is like it is coming out of the LMS, then you have an browser problem. Publish your entire course in HTML on your local drive and go thru it. Bulleted/numbered lists are a big offender. Also if you copied any text from an Microsoft application and pasted it in w/o pasting it unformatted, then you can expect things to look different. As to the window, not sure about that part. Try the above first and post your findings.Edited By: bpitman on 2007-2-21 16:44:51
