Screen Size and Layout Problems
February 22, 2007 12:00 AM
Window size: Well, on initial launch, the window size is the size of the last browser window UNLESS you launch the index page from something that controls the size - like some LMSs. Now, Lectora can control the size of a popup window and you can run your course in a popup but then you lose the LMS bookmarking.It has NOTHING to do with the Integrator. The link from the LMS might be able to specify the window size - check with your local HTML expert to see if you can do that. If not, you can have the first page in your course do nothing but open the second page (the real first page) in a popup window of the desired size. Also, there is some very recent postings (today I think) re. using a bookmark to restart the course.
