Hi Created a course in Lectora and export it to Scorm 1.2. I have the assignable unit set to score 100 and the test set to 100 however even if I get all 4 questions right the LMS will return a score or 75 and a status failed.
Any idea which setting I missed in Lectora or is the problem with the LMS.
Can you display the score in Lectora and make sure it's 100, not 75? Because it's much more likely that something is wrong with scoring the question as correct (or worth 25 points) than with Lectora-LMS communication.
