I feel your pain. When I started publishing to SCORM I had a difficult time figuring out what exactly I needed to do, and the Help file isn't very explicit.Did you go to the Title Properties and set this as a SCORM course? I had to do that in order to correctly set the completed variable.Go to the Title Properties, select the Content tab, select AICC/SCORM/CourseMill (3.x and above) Published Title, and click OK. This sets certain AICC/SCORM variables into the title. I then went to the last page of the title and added an action:Action Name: CompletedOn: ShowAction: Modify VariableTarget: Aicc_Lesson_StatusValue: completedModifcation Type: Set Variable ContentsI use Learn.com, so I can't vouch for PeopleSoft, but these were the steps I needed to get our Lectora courses to work in our LMS. I believe I contacted my LMS support for help in the beginning and they were able to help me a bit and were somewhat familiar with Lectora. I'd recommend doing the same.Good luck. Look forward to hearing what steps it took to get it to work.
