SCORM LMS error please help!
alight,Not familiar with Peoplesoft, but I have a thought, based upon the "imsmanifest.xml failed: No such file or directory" message in your error message. Looks suspiciously like a "404 file not found" warning. When you publish to SCORM web-based, Lectora publishes the files to My titles/ProjectName/scorm/HTML folder by default. Look in that folder for the imsmanifest.xml file (if you chose to publish to a zip file, look for it in the zip file).If the imsmanifest.xml file is in there, I'm guessing that something got screwed up in the upload process. In our new LMS, we just upload the Lectora-created zip file and things just work, but in our old LMS, the files had to be placed on a webserver, and then within the LMS, we had to manually type in the path to the launch page for the course (i.e. http://www.servername.com/coursename/a0001index.html). Very frequently the path was typed incorrectly and we were unable to launch the course. My gut says this is the case, but I have NO experience with Peoplesoft. I would have the people uploading your course double-check the launch path, and search the Peoplesoft forum for portions of the error message you received.Good luck. Let us know how it turns out.
