Hi, This is my first time publishing to scorm. I went to publish to SCORM 1.2 in Lectora 2007. When trying to upload the files to our LMS - Peoplesoft - I get the following error:Open of file: imsmanifest.xml failed: No such file or directory (2,633) LEM_UTILITIES.Utility.OnExecute Name:ReadFile PCPC:4407 Statement 83 CalledFrom:LM_LEM_IMPORT.GBL_IMP_CBS_SCORM12_FieldChange Statement41The open could not be completed because of the error.Can anyone tell me what I am doing wrong in Lectora or if you think its an LMS issue?I have a quiz, but the client doesnt need the answers to be saved. I tried to publish to Scorm 1.2 but it gave me two errors that I needed to fix, an Exit title error and a modify variable error. I believe that I fixed those because I was then able to Publish with no errors or warnings. I put an Exit title action on the last page and added a modify variable action of "complete" to the lesson_status variable.Are there anymore steps?Does anyone know if there is a step by step guide that shows the correct way to publish to SCORM?Also when I published to AICC the module successfully worked.
