For SCORM 2004, you have to set two variables to mark completion of a course.From the Lectora help:"A SCORM 2004 Conformant course requires the setting of an additional variable CMI_Completion_Status. This new variable is in addition to the AICC_Lesson_Status variable which should also be set in a SCORM Conformant course. The AICC_Lesson_Status variable determines the "passed" or "failed" status of the content. The CMI_Completion_Status variable determines when the student has actually "completed" the content."You may have to find out what values the LMS is expecting these variables to contain to show completion. Different LMSes look for "c" "completed" "Completed" etc.
