running flash, the lectora exits
November 20, 2021 12:00 AM
When running flash, the Lectora program exits. how to fix it?
Flash is not really supported by any web browser. You should move away from it, unless you have a very weird use case.
Can you specify exactly what you are doing when Lectora exits? Inserting a Flash item into Lectora? Previewing? Publishing?
when I enter a flash item into Lectora, the application immediately exits itself.
this event keeps happening when inserting a flash file into lectora
is there any solution for this problem?
Since no one is answering here (and probably no one on the forum is using Flash any more), I suggest you reach out to eLearning Brothers support.
