Results Help
You need to place an action in the course to modify the AICC_Lesson_Status variable to the value your LMS requires in order for the course to be marked as completed. Lectora does not automatically set the status as different LMS' require different values. If you want 50% to be the minimum passing score, then set a condition on the action so that the test score variable is greater than or equal to 50. If you don't see the AICC_Lesson_Status variable, make sure you have the title setup as an AICC/SCORM/Coursemill type of title. This can be found if you right click on the title icon in the left hand pane, select properties and click on the content tab. Ed
