The closest answer to my issue (at the end of this post) doesn’t jibe with my situation.I'm having a problem with getting a drag and drop question to actually reset in Lectora 2007. It has three pairs with no distractors. All drag items move OK when answering, but will not reset back to their starting place using the custom reset button. The actions are associated with the proper variable (Question_0006). All other questions (feedback and reset) work properly with the same actions (target variable changes). The following actions are associated with the reset button: Pairs: 3Distractors: 0Action 1On: Mouse ClickAction: Reset QuestionTarget: Question_0006Action 2On: Mouse ClickAction: HideTarget: Correct AnswerAction 3On: Mouse ClickAction: HideTarget: Incorrect AnswerBackgroundI'm working on a project to build quite a large number of courses, in an environment of mixed exposure to online learning, so I'm creating a template course and including a help chapter that will be in every course. Within it I'm building "Test Help" pages with un-scored sample questions to help learners who aren't familiar with online learning courses understand how to properly answer questions before taking the scored course tests.I did see the following , but I do not see a value field in the dialogue box. Where would I find that, or does this relat to an earlier version? Answer to http://community.trivantis.com/forum_posts.asp?TID=985&KW=dr ag+reset
Ben Pitman wrote:
1. Best solution is to get Lectora 2007 which has a Reset action for questions. This was not available when the original posts were made.2. You can reload the page. I have never use his version but I have seen the below around for a while with no complaints.Action: Modify Variable Target: any unused variable. Value: Javascript:window.location.reload()
