Recording Audio
I should qualify this a little. I also use a condensor mic and a pre amp that converts the input from a XLR connection to a USB computer input. I record at home and I hang blankets behind me to kill any echo. Using a poor quality headset mic and top of the line software will only result in more work on the editing side. The better your input the better your final product will be.
