Update - I'm not sure why I didn't think about this before, but Coursemill uses JSP pages vs. ASP pages. Using JSP code would allow you to relate the database fields right to a Java Variable - in turn, a Lectora Variable. I'm going through different books and references to see what I can find on pulling a SQL database field into a Java variable.Again, I'll keep you in the loop on this.
