You are correct in what you are saying. But, you can still use the test function within the first course. I'm looking into a way to extract that data in later courses like you are referring to. It's actually something I've been trying to do for quite sometime and we just hired a database guru that's going to help me figure this out tomorrow. I'll let you know the results...it will probably involve some asp coding like you were referring to. I just don't think it will require that much.You are correct in what you are saying. But, you can still use the test function within the first course. I'm looking into a way to extract that data in later courses like you are referring to. It's actually something I've been trying to do for quite sometime and we just hired a database guru that's going to help me figure this out tomorrow. I'll let you know the results...it will probably involve some asp coding like you were referring to. I just don't think it will require that much.
