Randomized test and IIS problem
Hi Neil,I have a couple concerns around your comments.You say to check for apostrahies in the question text. So if the question requires them, how can I get them in there without causing any issues?By asking if I copied and pasted the questions, are you referring to the question object? If so, I can't remember but I will try creating new objects from scratch.I will have to do this and re-test on Monday as I can't upload to the server from home. Failing all of the checks I will send you a copy of the random test as you suggested.Thanks again for the reply!
