Randomized test and IIS problem
Hello,I am new to Lectora and running into a major issue with the randomized test.Here is breakdown of our environment:- Lectora 2008 SP2- Publishing for HTML- Using aspx to communicate to DB from LectoraHere's what's happening:Running the files locally works fine with the randomized test. Running on a server without IIS, works fine too. Put the same files on a server WITH IIS and when you click the menu item called 'assessment', the test doesn't load. Based on the debug window, the onClick of the menu fires, just not the 'Go To' function. I want to also note, that the Next button (has an action of 'Next Page') on the last page before the Test Object. One more thing....by unchecking the random option on test properties solves this issue on IIS and the test loads.This is killing me so I thank anyone who can provide an answer to a good starting point to look.Any suggestions?Thanks again,Brook
