Randomized test and IIS problem
December 6, 2008 12:00 AM
There are a number of reasons this may be happening.The first is worth checking but sometimes stops it runnign at all not just randomizedI would start by loking at a number of potential isues in your course, specifically the test.Check your page names in the left column have no apostraphy or question marks '? this is the first issue that we have seen cause your issueSecond check the text in the questions and remove any apostraphy ' Second thing to ask. Did you copy and paste your questions - one to another? or did you add them all individually?If you have a really hard time seeing the issue, then it may be worth creating a new course and importing just your test to it. then exporting to zip and emailing it to me, sometimes you can see these really quickly when you never built it.Neil
