Quiz Score Zero - HELP!
There are a number of possible issues here.Are you using a progress bar? If so take it out of the randomised test as the test will fail to operate properly.Assume your questions all have goto next page as the button to move on?How are you trying to show the score? Change contents of text box?You should not have to post the test 'process' as moving off the last question should do this for you.do you show user the result in the lectora pop up box, if not turn it on and see what it reports.if it takes you to the right screen passed/failed if so then its working and you are maybe not picking up the correct variable for the page when changing content.
