Quiz Score Zero - HELP!
March 18, 2009 12:00 AM
Thanks to all! I got the 1st problem to work. Apparently had multiple issues originating with over-writing a previous quiz with new questions, but it worked when I deleted the quiz and recreated it using all the stuff above & double-checking everything.Is there a way to make a custom "quiz results" page that will show the score? It is actually the last page of the quiz (like the built-in one would be). In a regular quiz (not random) it already shows the correct answers, so I know it's picking up that info. I've found if I put the "submit/process" action right before the results, it jumps to the passed/fail pages rather than show the results. If I just "next page" to the results, the score=0. The "grade quiz" box is checked. What makes me confused is that the built-in results page is able to show the score, but how it does it is hidden from view In case you were wondering, the reason I created my own results page is that I have a multiple-choice multiple-correct-answer question & the built-in results page is a mess handling that, but I use the concatenated string of all the correct answers from the student in one "your answer" field & it looks much better & is easier for the student to follow.
