Quiz Problems
November 21, 2007 12:00 AM
Yes but not easy. Instead of using 1 drag and drop, use 1 for each drag item on the page. Here's how to give it the same look and feel.1. Create your background and place on page.2. create a transparent box (text or gif) about the size of your drag items. I would use one of Lectora's and set it to yellow to start and then change it to transparent later. Changing one will change all.3. Then create each of the drag and drop questions, use the yellow/transparent object for the drop. After you havae created one, drag the transparent drop to the right place on top of the background.4. Hide all but the first question text box.Now you can drag each drag item to one and only one place. If you need more explanation, call me at 678-571-4179. Other solutions available but take a bit more.Edited By: Ben Pitman on 2007-11-26 9:57:52
