Quiz problems again!
It seems as though Lectora does not add the right amount of points in total. There is an easy (though a bit timeconsuming) way to check.- Create a blank page- Add 8 fields- Add 8 actions- Let 7 actions fill the content of 7 different fields with the score stored in the resp. variables.- Let 1 action fill the last field with the contents of the math problem described earlier.This way you can check to see if the variables display the right score. It sounds to me the program adds too much points in at least 1 test.Good luck!
