Quickly Edit Hyperlinks--Quadruple Click
A quick way to edit existing hyperlinks is to quadruple-click on the link. Four quick clicks in succession opens the Text Hyperlink Properties window. It's the same four mouse clicks if you double click the link, right click to bring up the context menu, and then select "Edit Hyperlink," but if you have lots of edits, it can cut down on the mousing and tedium.
