Questions/Answers for reports
October 1, 2021 12:00 AM
How would I set it up in Lectora so my test sends the answer from each question to the LMS? I need to run a report later and see which questions were answered correctly and which were answered incorrectly for each student. Thanks in advance.
Solutions (2)
I believe that I may have asked the question incorrectly. Yes, it is the extraction piece from the LMS I am trying to figure out.
To answer a question about extracting info from the LMS, we'd need to know what LMS you use--there are no standards for how LMSes report data. You might want to post that question in the LMS forum, since it isn't about Lectora specifically.
Discussion (4)
Perhaps I am under-thinking this, but if the "The published course will report Test/Survey Question Interaction to the LMS" is checked, you should be all set. The task then becomes determining how to extract this information from the LMS.
Thank you so much for your guidance. I will give that a try.
