Question text flow in International
I've noticed that when I create a new question in Lectora Int. Publishing Suite, using a double-byte character set (such as Chinese), the textfields that are created for the Question Text and Choice Text values are very often too small. When published as aicc w/ javascript titlemanager, the text overlaps and is illegible. When I look at the question in Lectora, the textfields show the little plus signs telling me that the field isn't big enough for its text. Is there a fix for this, or a workaround?Thanks
