Pulling two tests from same question pool
November 12, 2006 12:00 AM
I think this is too much of a kludge personally. You likely can get it to work, especially if you do not have to report the pre-test score to the LMS or the Lectora Results page to the student - the one that shows all the questions. The pretest would show that they did not answer 1/2 the questions but you likely can get just the % to work and create your own page.I think this is too much of a kludge personally. You likely can get it to work, especially if you do not have to report the pre-test score to the LMS or the Lectora Results page to the student - the one that shows all the questions. The pretest would show that they did not answer 1/2 the questions but you likely can get just the % to work and create your own page.
