Pulling two tests from same question pool
Ok, here is somewhat of an idea. One thing you never said was what you do with the scores? Do you need to retain them and report to the LMS? If so, not sure this will work, especially the first score. What do you report to the students at the end of the pre-test.I don't deal with randomized tests or the LMS but see if you can get something like this to work. Run thru the same test twice!!! Have a test with two sections. All questions are in section 1 randomized. Section 2 has 1 page, reporting scores however you do that. Put a counter on each page. When it reaches 10 during the pre-test, jump to a page in second section. You are going to have to calculate the score yourself here. When you come back thru the test as a post-test, keep going until the counter reaches 20.
