Publishing to Plateau / Success Factors LMS using AICC HACP
When you are publishing to a Plateau / SuccessFactors LMS and you are using HACP AICC you need to set the lesson_status, simply having a scored test is not enough to set the status. To do this add an action with appropriate conditions and do a "modify variable" to the AICC_Lesson_Status variable and set it to "passed". You can use passed or completed but passed is best. The score is automatically submitted if you have a scored test, you must set the test to graded and included in the test properties.
Here are some helpful links:
http://lectoraonline.com/app/BN002169/help/default/en/index.html#7280.html?Highlight=completion status
http://lectoraonline.com/app/BN002169/help/default/en/index.html#2900.html?Highlight=test scored
If you do not see the AICC_Lesson_Status variable then you need to change the course type in your title options to be SCORM/AICC.
http://lectoraonline.com/app/BN002169/help/default/en/Content/630.html
