If you do not see the .awt file in your CD publish folder it is mostly likely because of a known bug in Windows XP. The problem is if you have Windows XP and the option to hide extensions of known file types is checked from the view tab in folder options, it causes the file to not be created correctly and is not given a file extenison.If using Lectora 2004, download the latest service pack update (SP3) and republish the content. Or it can be also be resolved by unchecking the option to hide extensions from the folder options from the Windows explorer.
