This problem is caused by Lectora's autoupdate utility, which is by default configured to run every 7 days. The update utility needs to have administrator rights in order to run. You can fix this by running Lectora in Admin mode within Windows Vista. To access Admin mode, right click on the program and choose the option to "Run as Administrator". Once the program is running again you can then go into the File/Preferences menu and under the Auto Update tab, uncheck the option to have it check for updates. This way you will no longer need to run the program in admin mode.This problem is caused by Lectora's autoupdate utility, which is by default configured to run every 7 days. The update utility needs to have administrator rights in order to run. You can fix this by running Lectora in Admin mode within Windows Vista. To access Admin mode, right click on the program and choose the option to "Run as Administrator". Once the program is running again you can then go into the File/Preferences menu and under the Auto Update tab, uncheck the option to have it check for updates. This way you will no longer need to run the program in admin mode.
