Problems with randomization in a test
Are your test pages inheriting the items you say are missing or is the "Inherit all" turned off? Typically tests will not inherit items unless you tell them to within the Properties tab of the test itself. This could be your issue. To get to the Properties, right click at the title level of your test and adjust the inheritance on the inherit page.I hope that helps you solve your issue.
