Problems with my FLVs
Thanks to all who responsed. It turns out the issue was that I neede to have "Initially visible" checked as well. If this is unchecked and even if the object has "auto-start" it evidently will not work.Since the .flv has the play pay window we made the image 1 x 1 pixel and moved it off to the side.Not ideal, but it worked. What is odd is that .wavs you import are not issues.
