Problems with AICC/Web-based export
Hi Hapgoods, Thanks for clarifying my road. Im getting the NO HTTP SUPPORT message when am using the java script title manager assistant. In fact without using it, I got java script mistakes that do not allowed the content to load (titlemgr.html and content.html stoped the loading due to mistakes in the web page)May be, as you mentioned at the end of your post, the fault is due to an action for bookmarking that I put at chapter level. On: ShowAction: Modify VariableDestination: AICC_Lesson_StatusValue: VAR(AICC_Lesson_Status)Type: Stablish variable contentI will try removing it and let you and the forum know.All the best for you all.Javier
