Problems with AICC/Web-based export
re you publishing with the JavaScript Title Manager? I can't quite tell.I've seen this error when the SUN JVM 1.4+ is running. What JRE are you running? If you are running the Sun Java JRE you might need to enable or install the MS JVM.What were the JavaScript errors you were getting with the JavaScript Title Manager?Scott
