Problems with AICC/Web-based export
August 1, 2007 12:00 AM
Griffin,I sent both my SP2 and SP3 exports through to Trivantis - and got this reply:"There does appear to be an issue with AICC courses and SP3. We have notified the developers about this issues and they will be making a fix for this ASAP. In the meantime if you can either publish to SCORM (if your LMS supports this) or revert back to service pack 2a you should no longer encounter these issues. We are very sorry for any inconveniences that this has caused you. If you have any additional questions, let us know."This followed on from the previous information that they had given me about reverting back to SP2:"If you would like to revert your version of Lectora 2007 back to service pack 2 you must uninstall Lectora from your machine, then re-install Lectora using a custom install and disable the auto-update feature. Once Lectora has been installed go to the support section of our website (http://www.lectora.com) and download service pack 2a"Hope that helps!
