Problems with AICC/Web-based export
jgomez -- I feel your pain.I've noticed that with the SP3a release these is an error in how certain actions are handled. If you have an ACTION with a CONTAIN (or DOES NOT CONTAIN) condition it then causes javascript errors to be thrown.Try changing the condition to EQUALS (or some other condition)to see if this is the problem. The other thing that you can try is publishing using the Java Title Manager.The CONTAINS problem first showed up in the SP2 release and I thought that it was fixed in the SP3 release, but I couldn't be sure because I couldn't get AICC published content to work at all.I believe that the AICC problems were fixed in SP3a, however because the CONTAINS issue is still there the course wouldn't load (I use internal bookmarking that uses that function) becuase it was throwing a JavaScript error.Scott
