Problems with AICC/Web-based export
Thought that I'd like to add on to this topic. I published the course to AICC and couldn't connect to the LMS, threw a JS error. When I published with using the Java Title Manager it worked. However, we have an error with SP2 that was breaking any actions that had a "Contains" condition, and that error is still there.It doesn't look as though much got made better by this update (or the one before). At this point I'm hoping for the SP1 update to be reconfigured to reinstall SP1, these last 2 have been a real pain.ScottBTW - If you copy an old version of the trivantis.js file from Lectora 2006 and replace (make a backup first) the one in the support files for Lectora 2007 it will work. You might loose some functionality, but it got me through a tough spot with SP2.
