PROBLEMS PUBLISHING TO LMS
We use the Learn Something LMS. My CBT seems to be having great difficulty when published. I am publishing under SCORM and have run the program in HTML and on my local browser with no problems. I don't know if maybe I didn't check something that I should have checked or didn't uncheck a block that I should have unchecked.The problem is that when published to the LMS, the audio stops playing on a certain slide and then the next button or the TOC doesn't function any more.Edited By: MarkG on 2009-1-12 14:58:48
