What do you mean by "I can not check for error either. ". Does the program also crash when you do the error-check from the menu? If so, maybe you are working on a protected drive? Maybe you have no administrational rights?Have you tried removing the menu (don't forget: make a back-up!!) and publishing it? If that works, then the error is obivous. If not, you should look at something external.Maybe try it on another PC? If possible?
