Problem With Users Cheating
Hmm, yes, it would seem that it's far easier for you to disable the Ctrl button. I suppose there might be a fairly easy automation task where you export to XML and then just run a batch process to add and remove text based on some find criteria. But, I fear that narrowing this down would not be any less labor-intensive than adding the Change Contents yourself.
In any case, your sacrifice has shown the rest of us the light. From here on out, I will keep in mind that hidden text and images can be copied and pasted. This fortunately does not affect our testing (which is provided by another application), but it is something to keep in mind.
Kevin
