Problem with text appearing when hidden
May 6, 2008 12:00 AM
I'm not completely following you, but I think I get the point. Being more explicit and telling which actions are being used would be helpful (on click, show x, etc.)That being said, are you using groups to get these actions to work? Grouping the actions then an action to run action group would likely do wonders. Also, what type of audio are you using? Is the above working at all? What about when published to html (if that's the ultimate goal).Russ
