Problem with Scorm-publishing
then you could either put your hyperlinks in seperate text boxes (that aren't rendered as an image when published) OR use a transparant button over the relevant text in the rendered as image text box (you can change the text to blue and underlined so that it still looks and acts the same way as a hyperlink).then you could either put your hyperlinks in seperate text boxes (that aren't rendered as an image when published) OR use a transparant button over the relevant text in the rendered as image text box (you can change the text to blue and underlined so that it still looks and acts the same way as a hyperlink).
