Ok,Thanks once again.If I render the text as Images, will this make the published file alot bigger? I 'm afraid that It might be to big to handle by the LMS(slow loading etc). By the way, The LMS we are using is Dokeos. I also feel that even though rendering text as images is one solution it doesn't feel optimum...There has to be some way of making the text work. Any ideas?
