Problem with retention of multi choice question answers
You need to use the action 'Reset Test/Survey' before allowing them to navigate back to the start of the test.
You can do this on one 'Re-take Test' button if you like. Just assign the button the following actions:
  1. On Click > Reset Test/Survey > TestName
  2. On Click > GoToPage > First Test page
davidlockett said:I have a test with multi choice questions in it which works and scores perfectly. However, if the user doesn't get 100% we give them the opportunity to go back through the content and then re-take the test. Unfortunately because its the same set of questions the users originally selected answers are retained when the user comes back to the start of the test. Is there a way to clear all selected answers when the test is restarted? It is not a new session as the users will still be in the module and I don't want to create a new set of test questions if possible. Thanks
