problem with radio buttons-Saba Publisher.
March 22, 2005 12:00 AM
I created a test on Saba Publisher 5.0 (2262). The test is composed of about 20 multiple choice questions. There is a problem with only 2 of the questions. When tested in Publisher, the radio buttons for the answers work fine, however, when published to the SABA LMS, the radio buttons do not work. The users are not able to select the radio button(s). Help...
Discussion (7)
Hi Aaron.I'm having the same problem lately. I suspected special characters so I tried hand typing the entries and pasting them on notepad first but the same thing happens. I am using Lectora 2007. I just finished some courses last Dec but never encountered this problem.
Gotcha, I have Saba Publisher version 6.o. I do not show any service pack enhancements for this product. Gotcha, I have Saba Publisher version 6.o. I do not show any service pack enhancements for this product.
What is the exact text of the answer choice for the radio buttons which are not working? Did you copy and paste them out of another program such as Word? If so, try hand typing them in to avoid special characters from getting copied over. Or paste into Notepad and then copy from Notepad and paste into Lectora in order to strip out special formatting.What is the exact text of the answer choice for the radio buttons which are not working? Did you copy and paste them out of another program such as Word? If so, try hand typing them in to avoid special characters from getting copied over. Or paste into Notepad and then copy from Notepad and paste into Lectora in order to strip out special formatting.
Is anything overlapping? are their layers, such as an image behind or in front of the answers?Is anything overlapping? are their layers, such as an image behind or in front of the answers?
Check to see if your distractors contain any semicolons ';'. I had this problem with multiple-choice multiple-answer questions. Removing the ';' fixed it.Scott
No overlapping objects Krixquet.This issue is fixed in SP5.
Hi Scott.There's no ";" in my choices. I noticed that everytime there's a space in the choices, the radio button doesn't respond to clicks. A "yes or no" or a true or false is OK but when the choice becomes a sentence the whole thing fails.
