Problem with Publishing to CDROM
You did the right thing by removing the HTML. Not heard of the second. Only thing I can suggest is to make sure everything else is close and Lectora is the only thing running. Try that. If you get same error, contact support@trivantis.comYou did the right thing by removing the HTML. Not heard of the second. Only thing I can suggest is to make sure everything else is close and Lectora is the only thing running. Try that. If you get same error, contact support@trivantis.com
